1995 GMC Suburban heater blower only works on HIGH
1995 GMC SUBURBAN
179,000 MILES • V8 • 4WD • AUTOMATIC
MARCW2
All fan speed settings do not work except highest. Checked under-hood fuse panel, could not find one that worked the fan, nor the dash mounted panel.
Is there a fuse for the lower speeds?
If not how do I access the part needing replacement?
Thanks!!
Dec 1, 2008 at 12:06 AM
  • 110,240 POSTS
Hi:
It sounds like a bad blower motor resister. I believe it's located on the passanger side firewall.
Feb 17, 2009 at 11:18 AM
