1995 GMC Suburban electrical carborater
1995 GMC SUBURBAN
190,000 MILES • V8 • 4WD • AUTOMATIC
HACKETT1991
i would like to clean my carborater with gumout carb cleaner. the carb has electrical parts and the cleaner tells to stay away from electrical connections. can i use the carb cleaner?
Jan 27, 2010 at 5:40 AM
OBXAUTOMEDIC
  • 3,711 POSTS
What you are calling the Carb is actually called the Throttle Body in newer vehicles. You can clean it but I suggest getting Throttle Body cleaner. The electrical parts you see are the Fuel Injectors.
Jan 27, 2010 at 6:19 AM
