1995 GMC Suburban
SCHOOL
  • 1995 GMC SUBURBAN
Electrical problem
1995 GMC Suburban
The powered driver seat and mirrors are not working in my 1995 Suburban truck. What can I do to fix it before taking it to a repair shop?
Tuesday, June 30th, 2009 AT 2:27 PM
BUDDYCRAIGG
  • 2,262 POSTS
Those probably go through a circuit breaker and not a fuse. Check that first, you might be able to plug a fuse in the spot that the circuit breaker goes just as test.
Tuesday, June 30th, 2009 AT 2:54 PM
KADE0610
Check the fuses. Look and see if the one for the cigarette lighter is broken. If not look in your manual towards the end and see the fuse diagram, It gives a list of everything hooked up to one fuse. If its nothing in the fuse box by the door, open the hood and there's another fuse box near your winsheild wiper fluid reservoir.
Saturday, July 18th, 2009 AT 12:12 PM
