1993 GMC Suburban Head Lights
1993 GMC SUBURBAN
196,000 MILES • V8 • 4WD • AUTOMATIC
REDWOLF0724
I was driving home last night when the head lights started flashing from high to low with out touching anything. Is this just the light switch or is it in the colum with the high beams. We have had the suburban for over 6 years and have never had any problems until now. The switch is not stable it move when you turn on the light. Please help as soon as possible as this is our only means of transportation and I drive 35 miles one way to work and we have about 2 foot of snow now so have to have head lights.
Dec 18, 2008 at 12:58 AM
DAVE H
  • 13,384 POSTS
if the switch is not "stable" you need to replace it ... the contacts inside could be flickering between high and low ?
Dec 18, 2008 at 1:50 AM
JEFFGSCISM
Most likely a short in the column mounted turn signal/dimmer switch, or in a wire in the steering column.
Dec 2, 2019 at 9:58 PM
Thanks for the addition to this post. This post was over 10 years ago so hopefully they have this fixed by now but I am sure that info will help others that may have this same issue.
Dec 3, 2019 at 12:17 AM
