1992 GMC Suburban rear end
1992 GMC SUBURBAN
FREE31208
1992 GMC Suburban V8 Four Wheel Drive Automatic
I was wondering if a rear end from a 1993 gmc surburan would fix into a 1992 gmc surburan. I can't read the code in the glove box to match it up.
Feb 2, 2009 at 2:01 PM
  • 110,194 POSTS
Hi:
That info I don't have, but if you do it, make sure it has the same axle ratio. If it is different from the front you are going to cause trouble with speed sensors, the 4wd will fight itself... I recommend getting the exact replacement.
Feb 17, 2009 at 7:10 PM
