1997 GMC Suburban INTERIOR LIGHTS
175,000 MILES • V8 • 2WD • AUTOMATIC
ALEX GAMBLE
I have an 1997 GMC suburban and the interior lights remain on at all times. I've checked the door switches and they all check out fine. The only reading I get that I am not sure of is the reading from the rear left side door the switches read a ground at all times, but when I remove the switch from the circuit the lights remain on. What do I do next?
Nov 6, 2008 at 5:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Not to insult but people do make mistakes so first thing to do is to check to ensure that you do not have the manual interior light switch in the on position. (It happens) Next, if it is not on, you should try disconnecting each switch one at a time because it does sound like a switch is bad. If you don't want to do this, you can pull the fuse as a temporary fix until you can find and have it repaired.
Nov 6, 2008 at 5:20 PM
