1991 GMC Suburban Swapped TBI to Carburator
JUSTJOSHIN83
Transmission problem
1991 GMC Suburban V8 Four Wheel Drive Automatic n/a miles
Vehicle had 454 with TBI, motor was removed. I installed a 350 with a carburator. Obviously creating many problems. This vehicle has a 4L80E transmission. Transmission does not shift properly.
Wiring harness is intact and connected to transmission but the computer is almost completely bypassed. None of the sensors are being utilized. No TPS, no MAP or MAF, no camshaft position sensor, no crankshaft position sensor.
Is it possible to improve shifting? If so, how?
Nov 9, 2009 at 5:36 PM
  • 31,937 POSTS
Hi there,
I feel that the lack of input to the ECU is causing the transmission control system to go into conflict, i don't really see how you can over come this problem.
mark (mhpautos)
Nov 9, 2009 at 7:21 PM
JUSTJOSHIN83
After checking around I found what I think may be a relatively inexpensive solution.
Many performance shops/sites have Manual Valve Body kits for GM transmissions. I understand this would not allow automatic shifting. These kits range from $150 to around $275. Any opinions, especially those of people who have used a manual valve body, are welcome.
Nov 10, 2009 at 4:04 AM
  • 31,937 POSTS
Hi there,
That is interesting option that i was not aware off, if you go down this path please re post with the results as i am sure that it will be valuable information to keep for others.
Mark (mhpautos)
Nov 10, 2009 at 7:22 AM
DOCFIXIT
  • 18,828 POSTS
A valve body from a THM 4L60 should work
Nov 10, 2009 at 7:39 AM
