1991 GMC Suburban
BOTHEMAN63
  • 1991 GMC SUBURBAN
  • V8
  • 100,600 MILES
It idales fine it when u take off it stalles and studers
Friday, September 17th, 2010 AT 8:27 PM
Hi botheman63, Welcome to 2carpros and TY for the donation
Lets start by checking the fuel pressure if its within specs if okay-check the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it and keep testing
Saturday, September 18th, 2010 AT 4:02 AM
