2002 GMC Suburban Engine stops no reason
65,000 MILES • V8 • 2WD • AUTOMATIC
GAYLORD SAYRE JR
Driving the vehicle and engine stops; won't restart.
Had the fuel pump checked - not the problem.
I have seen online it can be the Crank Shaft Sensor or possibly the "side impact sensor failing". Can you confirm these can be the possible problems? Can you send me a photo, diagram, or description where I can find these sensors please... I am stranded in Mexico.
Thank you,
Gaylord
Aug 12, 2010 at 1:13 PM
  • 75,988 POSTS
What liter engine??
Aug 12, 2010 at 2:06 PM
GAYLORD SAYRE JR
I don't have the vehicle here.. it's at the mechanic shop. I believe it is a 5.0, standard engine in the 2002 Suburban.
These are some comments posted on the internet.
"Yes I have had the same problem. I read that it might be the crankshaft position sensor which shrinks as it ages making it too short to contact engine. Engine shuts down to protect itself." and
" A sensor in the rear drivers door is bad it shuts off the fuel pump incase of a side impact. took many hours to find this out its been replaced never happend again ".
Where are these sensors located?
Aug 13, 2010 at 12:26 AM
  • 75,988 POSTS
The crank sensor is on lower right rear of engine block
Aug 13, 2010 at 10:40 AM
