1986 GMC Suburban Wobly steering colum
1986 GMC SUBURBAN
200,000 MILES • V8 • 4WD • AUTOMATIC
MADPATCH2
If I remove the steering colum can I tighten it back up to fix the movement in it or does it need relaced
Mar 10, 2010 at 3:20 AM
DOCFIXIT
  • 18,828 POSTS
Tilt steering wheel? if yes pull it apart put Lock-Tite on bolts that hold tilt mechanism to column.
Mar 10, 2010 at 6:30 AM
VEGASMSTRJ
  • 50 POSTS
had the same issue with my c10. i had to bring it to a mechanic to replace a few worn parts. they suggested i let a pro do it because it is pretty complicated.
Mar 17, 2010 at 11:33 AM
