My 1995 Gmc Sonoma with a 4.3 liter cpi v-6 will not start i replaced the fuel pump the crankshaft position sensor and i know the problem is fuel related because the engine has spark and will run on starting fluid if sprayed into the manifold so does this mean the injector is bad or what also it gets pressure to the port for the pressure gauge before the injector plenum the syptoms were if it started on the first try you were good but if not it wouldnt start until it was left to sit and now it wont start at all
Jan 6, 2007 at 3:37 PM
