GMC SONOMA HAS WHINING SOUND WHEN IN 2 WHEEL HI SETTING
80,000 MILES
BIGDOGBILL11959
GMC SONOMA HAS WHINING SOUND WHEN IN 2 WHEEL DRIVE HI SETTING, IF I SWITCH TO 4 WHEEL DRIVE HI SETTING THE WHINING NOISE STOPS. IT SOUNDS L[KE THE FRONT AXLE IS SPINNING FREE, AS IF NOT ENGAGED YET THE VEHICLE IS MOVING. IT IS VERY LOUD AT LOWER SPEEDS OR AT IDLE BUT COMPLETELY GOES AWAY IF I ENGAGE 4 WHEEL HI. PLEASE HELP
Apr 14, 2013 at 5:37 PM
it sounds like something in the transfer case is causing the issue.
have someone listen to it to be sure
Apr 14, 2013 at 6:31 PM
