2004 GMC Sonoma Fuel Problem
83,000 MILES • 6 CYL • 4WD • AUTOMATIC
TAD32287
Recently I went to start the truck and it started briefly then died. I then noticed that when I turned the ignition on I didn't hear the fuel pump kick in. I then opened the shredder valve and pressed the pin in with my key and got no fuel pressure. I removed the fuel relay and jumped it with wires from the battery and it still made a clicking sound. I then put the relay back and turned the key on and heard the clicking sound. I still don't hear the fuel pump kick in in. Could the relay still be bad or should I look at replacing the fuel pump?
Oct 22, 2010 at 2:56 PM
  • 75,988 POSTS
Power the fuel pump direct from the battery to rule it out
Oct 22, 2010 at 3:31 PM
