2004 GMC Sonoma Blowing cold Air.
11,200 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNFM
I would like to know how to fix the problem with my 2004 G.M.C. sonoma. 2 months ago, it started to blow cold air, I checked the Anti freeze, and it was low. I put in Dex-Cool and the Heater started working again.I just found out from my wife it is blowing only cold air again? Other than putting in more Dex-Cool, what else should I do?
Jan 28, 2010 at 5:34 AM
  • 75,988 POSTS
You might wanna start by replacing the thermostat and check if the heater core is clogged-up
Jan 28, 2010 at 6:45 AM
