Check the fluid level of the trans first (Idling in park) to see ifi t is low. If ok, you may need to service the trans (Filter kit) a partially plugged filter will do what you describe. If it is the original trans I dont suggest a full flush of the trans at that mileage, just drop the pan and change the filter and the necessary amount of fluid to bring it up to correct level (Approx 4 qts)
SPONSORED LINKS
Tuesday, January 19th, 2010 AT 8:13 AM
