2003 GMC Sonoma Electric window opener driver side
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICKS48
The driver side window does not open, it was progressive, only happening once in a while at first now will not open at all. I checked the fuses could not find if a fuse would affect one window, the passanger window works fine.
Jul 20, 2009 at 9:55 AM
HUMMAHUMMA
I had the same problem on my 1995 Sonoma. Driver's side window would not go down on occasion. Problem got worse. I ordered the window switch. The console pops off and the switch is just clipped in and can be pried out with a small flat blade screwdriver. Replaced the switch in 10 minutes and haven't had a problem since.
Aug 23, 2009 at 7:05 AM
RICKS48
HummaHumma,
Thanks for reply will give it a try, my son recently showed me how easy it is to pop console to get at switch.
Aug 23, 2009 at 7:28 AM
