2003 GMC Sonoma Could this be a computer issue?
2003 GMC SONOMA
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
LOKI0134
My service engine light is on, and has several codes. The brake light flashes intermittently, and once in a great while, all of the lights come on, the tach and odometer drop to 0, and then all goes back to normal. The gas gauge shows I have gas, but the truck will start spitting, sputtering, and popping, and losing power, like it's out of gas, but continues to run/start. I put gas in, and it's fine. I know I have more than one problem here, but I don't even know where to start.
Nov 5, 2009 at 6:45 PM
SERVICE WRITER
  • 9,123 POSTS
Lets start with the code numbers.
What brake light is flashing? one in the cluster? red one orange one?
Nov 5, 2009 at 8:58 PM
LOKI0134
codes are: P0120; P0420; P0101
The emergency brake light, on the instrument panel, that is red, is randomly on, or blinking, but very rarely is it off.
Nov 5, 2009 at 10:25 PM
SERVICE WRITER
  • 9,123 POSTS
Not sure how much I can stay with this this morning, but..
The po420 is catalyst effiency code. It does not necessarily mean the you need a converter. For example an exhaust leak in front of the converter can cause this code. Typically the CEL would be flashing when this code comes up or just before it.
PO101 has to do with air mismeasurement going into the intake. Look for a vacuum leak between the MAF and the throttle bore first. Clean the MAF with electrical cleaner.
I have no info on PO120 for this truck, but it is a throttle position code on the c series pickups.
Remove the air snorkel to the throttle, Tip in the throttle plate, any sign of carbon and I would suggest doing an intake cleaning and throttle bore service.
My thoughts are that there is a vacuum leak causing 2 codes and a build up of carbon in the throttle bore.
Check the brake booster vacuum line as well. Listen for any hissing to help you locate it and use a can of carb cleaner to spray it short bursts on suspected leaks. The vacuum leak will suck in the carb cleaner and change the idle temporarily.
Nov 5, 2009 at 11:17 PM
