2002 GMC Sonoma turn signal
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
MANIACALCHICKEN
When i turn on the left turn signal, the turn signal and reverse light both flash, i replaced all bulbs and the flasher and a new turn signal switch because the hazard button broke. And a new neutral safety switch.
Mar 20, 2009 at 7:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
You need to inspect wiring to the back-up indicator switch as well as the wiring to the multi-function (turn signal) switch. Usually this issue occurs when a ground wire has become faulty and not grounded properly.
Thanks for using 2CarPros.com!
Mar 20, 2009 at 7:05 AM
MANIACALCHICKEN
Thanks! i found the problem, the truck was rear ended and the trailer hitch hit the ground screw so i cleaned it up drilled it out ant put a new bolt on and it works great! Worth every penny Craig
Mar 20, 2009 at 8:21 AM
