Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sonoma
Exterior Light
Turn Signal
Switch
Replace/Remove
2002 GMC Sonoma Replace Turn Signal Switch
2002 GMC SONOMA
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
JACOBJAMES
MEMBER
1 POST
How replace Turn Signal Switch. Appears I need to pull the steering wheel after pulling the air bag.
Mar 22, 2010 at 7:08 AM
BLUELIGHTNIN6
Experienced Mechanic
first disable the SIR system. remove knee bolster. loosen steering column bracket nuts. remove upper and lower steering column trim covers. disconnect column bulkhead electrical connector. remove wire harness straps from column wire harness. remove switch retaining screws then remove switch from column.
Mar 22, 2010 at 10:22 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
