2002 GMC Sonoma Replace Turn Signal Switch
2002 GMC SONOMA
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
JACOBJAMES
How replace Turn Signal Switch. Appears I need to pull the steering wheel after pulling the air bag.
Mar 22, 2010 at 7:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first disable the SIR system. remove knee bolster. loosen steering column bracket nuts. remove upper and lower steering column trim covers. disconnect column bulkhead electrical connector. remove wire harness straps from column wire harness. remove switch retaining screws then remove switch from column.
Mar 22, 2010 at 10:22 AM
