2002 GMC Sonoma No brake lights
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
WONDERS20
Where is the multifuction switch that was talked about reguarding another S10. My brake lights don't work but my third brake light does. So I'm assuming the switch is okay because the upper third light works. I understand that the third is on an independent dedicated circuit. I found the hazard/flasher control box in the wiring diagram but can't find it in the truck.
Jun 20, 2010 at 3:48 PM
BMRFIXIT
  • 19,053 POSTS
Multifunction switch is in the steering column
and I don't know where you are going to find one for $10
Jun 20, 2010 at 11:34 PM
