2001 GMC Sonoma ABS - Brake Lights
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
REGGIE HILTON
The ABS light and Brake light come on and goes off whenever it pleases, someone said it's because the battery wasn't charged enough however, after charging the battery the lights still have a mind of their own.
Mar 17, 2010 at 12:05 AM
HMAC300
  • 48,601 POSTS
have apro see if he can get any codes from this as there may be an abs problem as well as a brake problem. Your grounds could be bad or corroded as well....
Mar 24, 2010 at 10:57 AM
