2000 GMC Sonoma Right-front Noises
2000 GMC SONOMA
113,000 MILES • 6 CYL • 4WD • AUTOMATIC
KOOTER7337
Not sure what the issue is .. someone suggested it was a CV joint on the right-front. The truck makes a woom-woom-woom noise in drive (only when moving forward) with vibrations. The boots look fine and undamaged.
Jul 24, 2008 at 11:26 PM
FEELGOOD71
  • 32 POSTS
you probably have a wheel bearing that is going.
you should take it to a technician to determine which one as noise from wheel bearings can travel through the truck and you could replace the wrong one.
this could also be a bad tire but still sounds like a bearing
Jul 25, 2008 at 12:25 AM
KOOTER7337
How much does a wheel bearing cost to replace?
thanks!!
Jul 25, 2008 at 1:29 AM
FEELGOOD71
  • 32 POSTS
bearings usually range from $100 to 190 u.s.
and most garages will charge an hour to replace it.
and that depends on the hourly rate
Jul 25, 2008 at 9:51 AM
KOOTER7337
The noise goes away when you shift it into 4wd High/Low.... but comes back when you put it back into 2wd .. what's up with that?
Jul 25, 2008 at 3:09 PM
