2000 GMC Sonoma rear end replacement
RUSS440_GTX
Drive Train Axles Bearings problem
2000 GMC Sonoma 6 cyl Four Wheel Drive Automatic
how do i know if i have over or under tightened the squash washer on the rear end
Jan 14, 2010 at 5:06 AM
HMAC300
  • 48,601 POSTS
i you have overtightened the crush sleeve then you will take out your bearings really quick. It may possibly make alot of noise as well when driving. Proper torque is 5-15in lbs of drag on thebearings with NEW bearings.
Jan 25, 2010 at 10:46 AM
