2000 GMC Sonoma
98,738 MILES • 6 CYL • 4WD • AUTOMATIC
BOYNTONDOUG
Truck used on remote Maine island. No mechanics.This truck starts fine, but when used for 10 minuites and turned off it will not restart. Leave it for 20 min or so and it will start fine. It has gas pressure.
May 11, 2009 at 10:22 AM
BMRFIXIT
  • 19,053 POSTS
When you try to restart
does it crank but will not start and have to wait 2o min for it to restart
or no crank and after the 2 m it will restart
you said that you have fuel pressure what about the spark
when was the last tune up !
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 11, 2009 at 11:18 AM
BOYNTONDOUG
turns over fine runs smoothly it just will not restart when warm getting gas and spark
May 11, 2009 at 11:24 PM
BMRFIXIT
  • 19,053 POSTS
If you have spark ,fuel and fuel pressure is at the spec
that leave security system and injector pulse
does it showing security light on and or blinking when it fail to start ?
check for injector pulse
also if you can access an OBDII reader check and see if any codes in memory and or pending
May 12, 2009 at 9:50 AM
