1999 GMC Sonoma scraping noise
1999 GMC SONOMA
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZHAGEDORN
My truck is mking a scraping noise. It use to do it about once a week and now it does it all the time. it will make the noise most often when i am turning left. The noises sounds like it is comeing from the back right side of my truck. I figured it could be something with the brakes. It sounds pretty bad and it will also make the noise sometimes when I am just driving straight going slow. It does it even when I am not brakeing. Can you give me any help. thanks
Jan 28, 2008 at 2:32 AM
MERLIN2021
  • 17,250 POSTS
You should have the BRAKES inspected NOW! you are most likley, running metal to metal! Soon you may have brake FAILURE!
Jan 28, 2008 at 2:39 AM
