1999 GMC Sonoma changing spark plugs
99,000 MILES • 4 CYL • 2WD • MANUAL
SOLCAMPOSJR
I can pull the plug wire next to fire wall pretty easy.Had to use both hands. Is there a tool one can use to grab plug wires and pull them off pretty easy ?
Or should I do something to the connected plug wire to loosen it from the plug connection making it easier to pull ?? help sol campos jr. thank you kindly
Nov 16, 2009 at 2:15 AM
  • 110,246 POSTS
All I do is take a pair of pleyrs, twist the boot and pull it off. Once you twis them, they should break loose.
Nov 17, 2009 at 9:41 AM
