1999 GMC Sonoma Another Question on the fuel pump
AMERZJL
  • 9 POSTS
1999 GMC Sonoma 6 cyl Four Wheel Drive Automatic
Can we replace the fuel sending unit with out replacing the whole fuel pump? the truck is a 1999 GMC Sonoma 4wd 6 cyl
Jan 17, 2009 at 10:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, you can. Removal and installation instructions are below..
REMOVAL/INSTALLATION:
Relieve fuel system pressure.
Disconnect negative battery cable. Raise vehicle and remove fuel tank. Remove sender unit and pump by turning cam lock counterclockwise using special service tool J-36608 or J-24187 (contact local dealer or tool supplier for tool)
Remove fuel pump from sending unit by pulling pump up into attaching hose while pulling outward from the bottom support.
DO NOT damage rubber insulator or strainer.
To install, reverse removal procedure.
Thanks for using 2CarPros.com !
Jan 17, 2009 at 11:08 AM
AMERZJL
  • 9 POSTS
Can you replace the sending unit by taking the bed of the truck off instead of droping the tank???
Jan 18, 2009 at 2:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes. That is the your decision. Most people just drop the tank, but you can remove the bed as well.
Jan 18, 2009 at 2:38 PM
