1999 GMC Sonoma 1995 GMC Sonoma Fuel Pump Question!
AMERZJL
  • 9 POSTS
1999 GMC Sonoma 6 cyl Four Wheel Drive Automatic
Is the fuel sending unit a part of the fuel pump that you buy or do you have to buy it seperatly, because I found a fuel pump for my truck(1999 GMC Sonoma 4wd) and it said it needed a strainer which i found at the same place but it didnt say anything about a sending unit! Which my fiance says the sending unit is what is going bad, but the price of the sending unit I found was just a few cents cheaper then the fuel pump I found! I really need some help on this! Thanks!
Jan 17, 2009 at 10:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello.
If you are buying the parts at an auto part store (and not a salvage yard) then the sending unit, fuel pump and strainer will all be seperate. If you are buying these parts used at a salvage yard then you will need to tell the employee there that you need the sending unit as well as the fuel pump.
Thanks for using 2CarPros.com!
Jan 17, 2009 at 10:33 AM
