1998 GMC Sonoma seepage on hoses and condensation
BENSONMUM
  • 1998 GMC SONOMA
  • 6 CYL
  • 11,200 MILES
What does seepage at the hose connection indicate?
Also, is it common for condensation to drip after driving the truck and turning off the engine?
Friday, September 11th, 2009 AT 7:52 PM
  • 31,937 POSTS
Hi there,
Just make sure that all the hose clamps are tight, if it has spring clip type clamps, replace with worm drive type check that the hose connections are not corroded as this will also be a reason that the loses can weep, where is the condensation coming from?
Mark (mhpautos)
Friday, September 11th, 2009 AT 8:58 PM
BENSONMUM
The dripping of condensation is coming from the passenger side - underneath the car.
Saturday, September 12th, 2009 AT 11:22 AM
  • 31,937 POSTS
Hi there,
This sounds like the a/c drain tube, the A/C system will dehumidify the air and excess moisture is drained away via a tube under the car.
Mark (mhpautos)
Saturday, September 12th, 2009 AT 7:21 PM
