1997 GMC Sonoma Radiator Fan
1997 GMC SONOMA
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
WASSIBBIDAVE
Radiator fan cames on at engine start (even when cold) and stays on for several minutes then shuts off
Mar 27, 2009 at 12:50 AM
JDL
  • 16,098 POSTS
Hello, if that is a belt driven fan, it will come run with the engine running. Thermostatic clutch?
Is the vehicle running hot or anything?
Mar 27, 2009 at 1:42 AM
WASSIBBIDAVE
[quote:8d61b5add5="jdl123"]Hello, if that is a belt driven fan, it will come run with the engine running. Thermostatic clutch?
Is the vehicle running hot or anything?[/quote:8d61b5add5]
Truck not running hot and fan is belt drven. Again it comes on (so far) on cold engine start but only staus on for 2~4 minutes after driving?
Mar 27, 2009 at 1:46 AM
