Do you have a check engine light On or has flashed?
After you installed the fuel pump did you check the fuel pressure.
Look at the injector/s spray pattern if its a TBI while running is it a cone looking shape and also not breaking.
If it continues to misfire check the EGR and engine compression
SPONSORED LINKS
Thursday, January 24th, 2008 AT 4:02 PM
