Hi there,
These are called torque to yield bolts, they should never be re-tensioned, if they are touched, I will guarantee another blown head gasket, torque to yield bolts should only be used once, then discarded, as for cost this can vary depending on what head work was preformed, ask the repairer if they used torque to yield specs, as if they did not you do run the risk of further problems sooner rather than later.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, August 3rd, 2010 AT 5:41 AM
