1997 GMC Sonoma ABS PROBLEM
ARTURO JIMENEZ
Brakes problem
1997 GMC Sonoma 6 cyl Two Wheel Drive Automatic
Anti-lock (ABS) lite on and i just fixed my brakes a week ago, but the abs light stays on and it does not allow my windows controls to work.What you think its the problem?
May 24, 2010 at 4:30 AM
DREWSIEFKER
I am also having the same problem. When I hit the window buttons it does not go up and down and the ABS light comes on until I let go of the button. The ABS light also comes on when I turn on the AC, and the AC does not work.
Have you figured anything out that fixed your problem? I have replaced the battery and the connections because it was bad. I have also had the alternator check and it is working properly.
Jun 1, 2010 at 7:33 AM
