1997 GMC Sonoma
TSMITH0602
Electrical problem
1997 GMC Sonoma 6 cyl Two Wheel Drive Automatic
my truck started missing out getting radom misfires so i tuned it up the next day it started doing it again then the abs light came on and the speedo dropped and the transmission kept losing power and now it wont start.could it be the computer
Feb 12, 2009 at 2:40 AM
JDL
  • 16,098 POSTS
Hello, if it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If you have good spark everywhere, check fuel pressure. Start with the basics. If you do a lot of testing with the vehicle cranking, you may need to disable the fuel system.
Feb 12, 2009 at 3:44 AM
TSMITH0602
[quote="tsmith0602"]Electrical problem
my truck started missing out getting radom misfires so i tuned it up the next day it started doing it again then the abs light came on and the speedo dropped and the transmission kept losing power and now it wont start.could it be the computer now i cant even read the codes and he ses light keeps flahing
Feb 14, 2009 at 10:54 AM
JDL
  • 16,098 POSTS
I'd do some basic tests and see what it shows? No spark, no fuel, what?
Feb 15, 2009 at 2:53 AM
