1996 GMC Sonoma timing chain replacement
1996 GMC SONOMA
115,000 MILES • 4 CYL • 2WD • MANUAL
PAPA RON
how do i replace the timing chain and what is the recommended mileage when this should be done?
Dec 11, 2009 at 3:06 AM
SWILLIAMS
  • 597 POSTS
There isn't a real interval for the timing chain. it is replaced as required. You can do it if you like, You will want a manual to do the job because there are some visuals that will help you a lot.
Dec 17, 2009 at 5:38 PM
