1996 GMC Sonoma oil pressure
1996 GMC SONOMA
OLDFART52768
Engine Mechanical problem
1996 GMC Sonoma 4 cyl Two Wheel Drive Automatic
I have good oil pressure when engine is cold(40PSI). as temp rises the oil pressure drops. I replaced the oil pump but it did not help much.
Sep 21, 2010 at 1:36 PM
Oil pressure drops to what? could be engine bearings problem
Sep 21, 2010 at 3:22 PM
OLDFART52768
almost nothing
Sep 26, 2010 at 4:49 AM
If there's no engine knocking noises and you're reading off from the dash gauge-I suggest you use a mechanical gauge and hook it up to where the oil pressure switch and check it there-if its the mechanical gauge-try checking the oil pump.
Sep 26, 2010 at 9:39 AM
