1996 GMC Sonoma help please
1996 GMC SONOMA
ITTTECHSTUDENT2012
Engine Mechanical problem
1996 GMC Sonoma 6 cyl Two Wheel Drive Automatic
1996 gmc sonoma while excelerating truck wouldnt excelerate any more and check ingine light and check gages turned on. when i pulled over truck shut off when i tryied to start it back up truck started but then shut back off. truck lost power put then it came back did that three times and the mph gage jumped to 50 and whent back down now it wont start and it just clicks when i turn key.
Jul 10, 2010 at 5:11 AM
HMAC300
  • 48,601 POSTS
have your battery checked as you might have a charging problem or the battery is bad. From the way it sounds that is what your problme seems to be.
Jul 24, 2010 at 2:49 AM
