1995 GMC Sonoma altenator
RAYCO51
  • 1995 GMC SONOMA
Electrical problem
1995 GMC Sonoma 4 cyl Two Wheel Drive Automatic
wont charge with new altenater
Monday, April 6th, 2009 AT 9:43 AM
BILLYMAC
  • 2,204 POSTS
Hi, check the fusible links. They will be connected at the starter or at the elec distribution box. Test both ends with test light. Pull lightly on them look for soft insulation. If one of these are broken or burned in two no charge. Check grounds on eng batt term clean and tight. Good luck billymac
Sunday, April 12th, 2009 AT 7:51 PM
