1994 GMC Sonoma rattle noise?
1994 GMC SONOMA
MAICOH
Transmission problem
1994 GMC Sonoma 6 cyl Four Wheel Drive Automatic 200K+ miles
I had the transmission filter and fluid changed and the catalytic converter replaced in February. Now I have a rattle noise whenever I'm stopped and in gear(stop sign, red light, etc.). As soon as I start going again or put the truck in park the noise goes away. Any ideas on what it might be? thanks.
May 29, 2008 at 4:55 PM
LEGITIMATE007
  • 5,121 POSTS
yeah, its more than likely a heat shield or you muffler
May 29, 2008 at 5:00 PM
ALIENH
  • 7 POSTS
I had the same problem when i took off from a stop I thought it was the heat shield too I found it was a loose brake line vibrating by the firewall it had popped out of the nylon bracket
Feb 14, 2009 at 7:27 PM
