1994 GMC Sonoma
225,000 MILES • 6 CYL • 2WD • MANUAL
ENER
After I had clutch & fuel replaced, the ABS brake light stays on, could the mechanic have knocked something off or coinsidence?. I've had brake guys look at it but no one seems to know. I went online for recalls & it seems there was one for this item (Recall ID #'s 72432 & 72371).
Mar 15, 2010 at 12:27 PM
  • 75,988 POSTS
Try clearing it do below
Turn ignition on. Using a jumper wire, connect DLC terminal "H" to terminal "A" for 2 seconds. Remove jumper wire for one second. Again, jumper DLC connector terminal "H" to "A" for 2 seconds. Remove jumper wire. Fault codes are cleared when ANTILOCK and BRAKE lights illuminate, then turn off. Turn ignition off. Check to verify codes are cleared. See RETRIEVING CODES.
Mar 15, 2010 at 12:39 PM
