1993 GMC Sonoma fuses
1993 GMC SONOMA
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
JB1939
The fuse that controls lighter, dome light. map light and glove comp. light blew. When i replaced it, it worked for a while then melted. I replaced it again, and the same thing happened, it was hot enough to burn my fingers. It is a 20 A fuse. It also drained the battery. What to do?
Apr 12, 2008 at 12:56 PM
MASTERTECHTIM
  • 4,750 POSTS
most common cause is the cigarette lighter housing. try unplugging it and see if the short goes away.
Apr 12, 2008 at 12:58 PM
