1993 GMC Sonoma catalic convertor
1993 GMC SONOMA
TONIO1726
  • 6 POSTS
Engine Performance problem
1993 GMC Sonoma 6 cyl Four Wheel Drive
My engine doesn't stay on and I notice my catalic convertor is gettin super hot. I just replaced spark plugs fuel filter and the fuel pressure regulator. I don't know what is makin my cat gettin too hot and it smells really bad.
Oct 16, 2010 at 3:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
converter could be stopped up causing these issues or timing could even be off causing symptoms.
Oct 16, 2010 at 3:29 PM
TONIO1726
  • 6 POSTS
Could the coil or the distributor have anything to do with the problem?
Oct 16, 2010 at 3:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
possible but should throw the check engine light on
Oct 16, 2010 at 3:36 PM
TONIO1726
  • 6 POSTS
If I remove th e cat would that fix the problem?
Oct 16, 2010 at 3:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
removing converter is never a good thing to do because it will effect emissions as well as MPG of vehicle and will also make check engine light remain on. you wouldn't pass emission testing if required in your area with a removed converter..
Oct 16, 2010 at 3:39 PM
TONIO1726
  • 6 POSTS
By changing my cat would that fix my problem with the engine not staying on
Oct 17, 2010 at 6:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if the cat. is indeed clogged then yes
Oct 17, 2010 at 11:53 AM
TONIO1726
  • 6 POSTS
I just changed the cat on my truck but its still not working right. It was a bad cat but it didn't solve the problem. Got any ideas on what could it be?
Oct 17, 2010 at 2:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check compression in cylinders , timing may be off which would cause the cat. to get hot and engine to not run .
Oct 18, 2010 at 8:34 AM
TONIO1726
  • 6 POSTS
How do I check compressionin the cylinders? Is it too hard to do? Would that fix the timing or do I need to get that checked out too
Oct 18, 2010 at 2:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it's not hard to do, you just need a compression gauge. if its low on all cylinders than it is a good indication that timing may be off. follow this link to learn how to check compression https://www.2carpros.com/dia/how_to_check_compression.htm
Oct 19, 2010 at 1:15 PM
