1992 GMC Sonoma STILL RUNNING HOT????????????
1992 GMC SONOMA
157,889 MILES • 6 CYL • 2WD • AUTOMATIC
SD2681
In the last month I've installed a new radiator, water pump, belt, top & bottom hoses, and 3 new thermostats and flushed the system and with the thermostat installed it runs hot, when I take it out runs fine, WHY???????
Dec 2, 2009 at 12:47 PM
SWILLIAMS
  • 597 POSTS
How hot is hot? With the correct 195 thermostat the temp should run about 200-205 degrees.
If it is running hotter it could be a partly plugged exhaust, leaking head gasket, or even the wrong water pump.
Dec 6, 2009 at 11:28 AM
