1991 GMC Sonoma Replacing Front Turn Signal
ADAMCRACKR
Electrical problem
1991 GMC Sonoma Two Wheel Drive Manual
I can't gain access to the bulb on the front turn signal in order to replace it. I can access the lower turn signal from behind the bumper, but the signal that is next to the headlight isn't accessible. There are no screws around it and I can't get to it through the engine compartment.
Jan 10, 2010 at 2:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yours has the 1-piece headlamp bezel so you must remove the grille assembly and support it on the bumper as you work to gain access to the front marker bulb.
Jan 13, 2010 at 6:33 AM
