1991 GMC Sonoma neutral safety swith
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEORGE48
My truck won't start. Already checked the usual things. I was getting it to start in neutral but not at all now.
1. How can I tell if it is the neutral safety switch. When i put the truck in reverse the lights worked. Could it still be this swith?
And mostly, what I am having a hard time with:
2. WHERE IS THE NEUTRAL SAFETY SWITCH IN MY MAKE AND MODEL.
Thank you
Apr 21, 2010 at 12:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is engine cranking at all? if so then it's not switch..also doesn't have neutral switch, has transmission position switch which is at the base of the steering column.
Apr 24, 2010 at 3:41 PM
