Transmission Problems
KEMOSOBIE
I have a 1981 2WD GMC Sierra Classic automatic and i just got the engine replaced yesterday with a 350. When i drive the vehicle, it seems like its not shifting into second gear. The engine revs really high and just stays in 1st gear. Eventually after awhile the truck makes a clunking noise and lunges forward and finally switching into second, but stays in second. Before this it just reved really high and changed, but after i filled up the tranny fluid after it was very low, this problem was produced.
I know for a fact that there is no leaking either. Where could the fluid gone ?:P
What ya think the problem is?
Mar 5, 2006 at 3:19 PM
RUGRUV
  • 45 POSTS
sounds to me like your kick down / TV cable is out of adjustment. If you have a Haynes manual, there are simple instructions there that could help you adjust it. Otherwise, stop by the dealer or a good tranny shop and they should check the adjustment for you.
Mar 6, 2006 at 2:17 AM
