HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Sierra
Engine
Oxygen Sensor
Oxygen sensor
DGREEN
MEMBER
GMC SIERRA
I have a 1997 GMC sierra with 194,000 miles on it how do you know if the O2 sensors are going bad
Friday, June 15th, 2007 AT 6:45 PM
DGREEN
MEMBER
The fuel filter is located on the drivers side on the bottom of the fuel cell behind a plastic cover
Friday, June 15th, 2007 AT 6:48 PM
DANIMALGMC
MEMBER
The vehicle will not run correctly with a bad O2 sensor (usually black smoke, poor mileage).
The engine light should also come on.
(1997 GMC Sierra 98000)
Monday, June 25th, 2007 AT 10:03 AM
Please
login
or
register
to post a reply.
Related Oxygen Sensor Content
How Many O2 Sensors Do I Have?
Says On O2 Sensor Is The Code Parts Store Computer Says 2 Required But I Found 4 On Truck How Do I Know Which One Is Bad And Could It Be...
Asked by
Jeriman
1996
GMC SIERRA
GUIDE
Oxygen Sensor
Oxygen sensors are made of reactive materials which limits their lifespan. Aside from mechanical failures such as shorted heating elements or physical damage, these sensors...
1989 Gmc Sierra Truck Won't Idol And Engine Floods
The Truck Will Start But Idols Too High. After It Warms Up It Floods And Won't Start Again Unless The Gas Pedel Is To The Floor. It Quits...
Asked by
12grands
1 ANSWER
1989
GMC SIERRA
Someone Turned The Top Of The Air Filter Upside Down....
Someone Turned The Top Of The Air Filter Upside Down. It's Been Having Stall Out Problems.I Didnt Know About It Till I Looked Under The Hood...
Asked by
Anonymous
1 ANSWER
1995
GMC SIERRA
Engine Is Tight And If I Flush All That Out It Will...
So My Truck Is Up For An Oil Change. This Truck Has Been Passed Down And My Grandfather Has Had It For 7 Or 8 Years Without Changing The Oil...
Asked by
savannahstruck21
1994
GMC SIERRA
Broken Engine Block
Hi, I Have A Gmc Sierra 2500 (6.0l, 8 Cyl.). The Engine Block Is Broken By Cylinder Failure. Plz. See The Attached Image. The Hole Is 4"...
Asked by
Alan
1 IMAGE
2001
GMC SIERRA
VIEW MORE
Oxygen Sensor Replacement Fix Code P0155
