2004 GMC Sierra Hybrid GMC Hybrid Power Steering
2004 GMC SIERRA HYBRID
110,000 MILES • V8 • 4WD • AUTOMATIC
GDUDMAN
The Power Steering/Brakes Hydraulic pump is not operating. I have fluid, the pump is not operating and I have 37-40 volts at the plug.
Is ther a control circuit that can be troubleshot or can the pump be checked before I spend 500 bux for a new pump
Mar 5, 2010 at 8:43 AM
MATHIASO
  • 1,209 POSTS
Hello gdudman
If you have 37-40 volt at the motor and the pump is not working, check for continuity between the motor and the pump.
if there is continuity, replace the pump.
if there is no continuity, search for an open between the two.
The hydraulic pressure is provided by the pump driven by the electric motor.
Mar 6, 2010 at 11:23 AM
GDUDMAN
I replaced the pump and still no-go. Is there a control circuit or module that controls this
Apr 21, 2010 at 6:59 AM
MATHIASO
  • 1,209 POSTS
To be more specific I have the following
· Sierra 1500 4WD
· Sierra 2500 4WD
· Sierra 2500HD 4WD
· Sierra 3500 4WD
tell me which one is yours.
Apr 21, 2010 at 6:13 PM
