1997 GMC Sierra Sway Bar Link Broken
TSHARK
1997 GMC Sierra Ext Cab Z71, 125,000 miles 5.8 Liter V8. How do I replace the stabilizer bar link? I found and bought a kit which included a bolt, nut, sleeve and some various bushings, but there are no instructions. Nor have I been unable to locate a manual which describes this procedure. The library had a Chilton for various models that year, but it did not include the Sierra or anything that closely resembled this part. Are there any special tools needed?
Sep 27, 2007 at 9:44 AM
MERLIN2021
  • 17,250 POSTS
if you put a socket over the nut on the threaded end and rock it back and forth, it will snap off, or see if it will unscrew! the links connect the sway bar to the lower control arms, undo both sides then put em both together by hand before tightening!
Sep 27, 2007 at 10:51 AM
Suggested Repair
Place a socket over the nut on the threaded end and rock it until the seized fastener snaps off, or unscrew it if it turns. The links connect the sway bar to the lower control arms. Remove both sides, then assemble both links by hand before tightening.
Conversation Summary
The owner of a 1997 GMC Sierra with a broken driver-side stabilizer bar link bought a bolt, nut, sleeve, and bushing kit but found no instructions and asked whether special tools were needed. The expert said the links connect the sway bar to the lower control arms, advised freeing a seized nut with a socket or unscrewing it, and recommended undoing both sides and assembling them by hand before tightening.
